Activity › Forums › Adobe After Effects › Keyframes not working properly when using the Expression Slider Effect
  • Keyframes not working properly when using the Expression Slider Effect
    Posted by Chris Huggett on November 22, 2006 at 10:14 am
    Hi guys
    I have a nested comp in a master comp. The nested comp has many other comps. In the master comp, i have 4 null objects. each has 10 expression sliders. Many of the comps in the job require a blur at certain times in the project, and as such, i have a blur effect to each. However i have used the expression pick whip to link each blur to the respective expression slider in the master comp.
    This is where it starts to go strange. When i apply two keyframes from 0 – 100, the blur does not animate and no matter where i place my timeline needle in the comp, it always holds the value of the first keyframe. So if it should animate from 100 – 0 over 3 secs and i place my timeline marker at 5 seconds, it still holds the value of 100.
    What could cause this?
    Cheers
    Chris
    Mylenium replied 19 years, 10 months ago 3 Members · 5 Replies
  • Tobias Pfeiffer
    November 22, 2006 at 3:16 pm
    strange.
    only a quick suggestion, need to leave right now.
    how about:
    valueAtTime (t)
    [cant check the syntax right now]
    this should fix it. or not?
    payton
  • Mylenium
    November 22, 2006 at 3:27 pm
    Make sure your relative temporal placement is synchronous in each comp. Ideally each comp should have he exact same length to avoid any confusion. If you are offsetting in- and out points in relation to the main comp, sliders will actually work, but at a different time in th sub-comp. To compensate, subtract the in-point values from offset layers ort use the valueAtTime() method where appropriate like Tobias said.
    Mylenium
    [Pour Myl
  • Chris Huggett
    November 22, 2006 at 11:06 pm
    Thanks for the replies guys. How would i write this into my expression if my expression looks like this?
    comp(“MASTER DEPTH OF FIELD”).layer(“Shot 1 DOF”).effect(“S1 – Shot 2 behind Martha”)(“Slider”)
    Cheers
    Chris
  • Chris Huggett
    November 23, 2006 at 1:11 am
    I think i understand now… i need to set t- “the number of frames” that each is delayed by. Thing is, everything is so burried, comps in comps in comps. Its a massive HD job and my computer isnt the fastest. It takes forever to open a comp. Is there not a way, where the time in the master comp can ripple down into the subcomps without the “- number of frames” code?
    Chris
  • Mylenium
    November 23, 2006 at 12:25 pm
    Nope. Time is a composition property unique to each one of them (as evident by the fact that each comp can have its own framerate, start time and a few other things). You have to take that bitter pill unfortunately.
    Mylenium
    [Pour Myl
