Activity Forums Adobe After Effects Keyframes not automatically changing value AE 2020
  • Keyframes not automatically changing value AE 2020
    Posted by marc maze on August 28, 2022 at 5:56 pm
    <div>AAE 2020, have several 3D .mov clips in a composition, with a 2d JPG background, with 1 node camera added…
    </div><div>
    1. When setting a keyframe on camera timeline, then move the head to a different time to set a new keyframe, the values do not change automatically to reflect any change in any of the x,y,x properties.
    2. If I manually set a keyframe at the beginning, 0 time, of the video clip, move to a later position of the timeline, manually create a second keyframe, the first keyframe then reverts to the value of the new keyframe.
    3. The keyframe values are set to Linear.
    4. To enhance the quality of the video, I have added Detail Preserving scale and Unsharpen effects to each of the 4 individual .mov files in the composition box
    Previous projects worked just fine, keyframe values automatically changed as I moved/altered camera position and orientation using mouse to slide video over, zoom in on someone, swing position around, etc.
    Marc Maze
    </div>
    marc maze replied 4 years ago 1 Member · 1 Reply
  • marc maze
    August 28, 2022 at 6:05 pm
    I have auto keyframe enabled
