Activity Forums Adobe Premiere Pro Keyframes in Submixes
  • Keyframes in Submixes
    Posted by Matt Chapman on March 26, 2019 at 9:16 pm
    Hi all-
    I have 50 sequences that all have to be combined onto one timeline. Everything was mixed nicely in each sequence, but now that its all on one timeline, the mixes are off.
    this is because different editors set different levels for each of the submxes (dialogue, music, SFX). I thought I could just keyframe each of the submixes to match the settings, which would be the fastest way. But I’m not seeing any reaction on the levels when I keyframe a submix. Why woudl this be? They are currently set to “READ”
    thanks!
    chap
    John Pale replied 7 years, 5 months ago 3 Members · 3 Replies
  • Matt Chapman
    March 27, 2019 at 5:14 am
    Hmmm.. thanks, though there is still more editing to do.
    Can you NOT control your submix volumes with keyframes on the timeline?
    that’s the main question.
  • Herb Sevush
    March 27, 2019 at 12:42 pm
    [matt chapman] ” Everything was mixed nicely in each sequence, but now that its all on one timeline, the mixes are off. “
    When you consolidated to a single timeline did you bring in the segments as a nest or separated into their individual tracks? To do what you want they should have been brought in as nests, then you can make the adjustments on the timeline like you want yet still have the ability to open the original segments to make changes.
    Herb Sevush
    Zebra Productions
    nothin\’ attached to nothin\’
    \”Deciding the spine is the process of editing\” F. Bieberkopf
  • John Pale
    March 28, 2019 at 1:18 am
    You have to route the tracks you want to be controlled by the Submix at the top of Track Mixer (you can do it in the timeline, too, but the track mixer is easier and more obvious)
    The default setting is for all tracks to route to your main mix, which means the submix does nothing.
