Activity Forums Adobe After Effects keyframes have disappeared…
  • keyframes have disappeared…
    Posted by James St clair on March 29, 2011 at 4:01 pm
    Hi, I am working on an animation of a PSD layered composition, everything’s going fine, I have about 6 keyframes on the timeline marking camera movement and one layer’s movement. I save the file, close the project, later re open the project
    and all of the keyframes have disappeared from the timeline. The correct movement of camera and layer is still happening, but I cannot see where the keyframes are to make further edits.
    How do I get these keyframes to re appear?
    thanks
    JSC
    James St clair replied 15 years, 5 months ago 3 Members · 3 Replies
  • Bret Williams
    March 29, 2011 at 4:10 pm
    Twirl down the little triangle next to the layer.
    Or, if you only want to see the animater properties, highlight the layer and press U. Also known as the uber key. I have no idea why.
  • Jason Mettler
    March 29, 2011 at 10:53 pm
    Uber key because UU shows up all the stuff you’ve done to the layer.
  • James St clair
    March 30, 2011 at 4:43 pm
    Thanks Bret and Jason
    what I discovered is that – for instance on the camera layer – I animated the position in the first session. After reopening the project, if I select the camera layer in the timeline, and press the p key, it opens up the position sublayer underneath the “Camera” layer again, with all it’s keyframes again visible.
    I would prefer to keep all those sublayers visible, and don’t know why they want to disappear when I close the project. Is there a preference somewhere I can tell the progam to keep that information active in the timeline?
    thanks,
    JSC
