Activity › Forums › Maxon Cinema 4D › keyframes
  • keyframes
    Posted by Gon Perdigao on February 21, 2009 at 6:05 pm
    Hi there, i have a time line with keyframes, and i want to increase/decrease the time, but i want to have the same proportion. I do this in After Effects sellecting all the keyframes and pressing the alt key i do this, how can i do that in cinema 4D?
    Thanks a lot
    Gon Perdigao replied 17 years, 7 months ago 2 Members · 6 Replies
  • Nolan Scott
    February 21, 2009 at 10:36 pm
    Using R11 / OSX 10.4.11
    In the Timeline select the Summary-folder / that should select all keyframes…
    and a yellow-bar on top of the Timeline-window…
    Move the handles (Left and Right) to your desired position…
    all keyframes will move relatively…
    Cheers
    Nolan
  • Gon Perdigao
    February 22, 2009 at 12:35 am
    thanks a lot for your reply.
    i miss explain, i want to make a stretch of all keyframes.
    In the way you say all key frames move, they don’t stretch
  • Nolan Scott
    February 22, 2009 at 1:56 am
    Well, I guess, I don’t understanding your meaning of stretching…?
    Here is my version of stretching and moving…
    https://web.mac.com/nolan.scott/Gallery/stretching_keyframes.html
    Cheers
    Nolan
  • Gon Perdigao
    February 25, 2009 at 6:59 pm
    that is what i want to do.
    There is a key that i have to press to stretch the key frames? I ask this cause i can’t do it, i already press the shift, command, control and alt key with no success
  • Nolan Scott
    February 25, 2009 at 9:16 pm
    Using R11 / OSX 10.4.11 / Wacom Intuos 2
    Well, I don’t press any modifier-keys at all…
    when you mouse-over the edges (slightly more yellow) – (left and right)…
    you should see a yellow square… press and drag…
    (otherwise you should see a yellow double-arrow)
    Cheers
    Nolan
  • Gon Perdigao
    February 25, 2009 at 10:38 pm
    i got it, i was doing it wrong.
    Thanks a lot, for your reply
