Activity Forums Maxon Cinema 4D Keyframed objs + Random Effector = Broken Animation
  • Keyframed objs + Random Effector = Broken Animation
    Posted by Aaron Pozzer on November 24, 2015 at 6:40 pm
    so, i did some simple animation on some objects, and decided that to add some visual interest id add some randomness to them. Put all the objects in a fracture, added the random, and it seemed ok until i scrubed. All the objects jump around randomly, no pun intended. I was under the impression the random would simply offset each objects position and keep it there. This almost seems like its reevaluating each objects random position on each frame. I played around with all the settings and I cant seem to figure it out.
    I only noticed this AFTER i let my project render for 7 hrs. So, my first thought was the fracture needs a mograph cache tag, but that didnt solve it. So, i need to figure out the underlying issue before i do anymore caching and rendering.
    File for refrence…
    https://www.dropbox.com/s/9jpxm5z7a2xrmw9/random%20animation.c4d?dl=0
    thanks.
    Aaron Pozzer replied 10 years, 9 months ago 2 Members · 2 Replies
  • Brian Jones
    November 24, 2015 at 7:33 pm
    you probably want the Random Mode in the random effector to be Noise or Turbulence those are smoothly animated noises, the Random and Gaussian are truly random.
  • Aaron Pozzer
    November 24, 2015 at 7:45 pm
    thanks brian. that seems to have done it. i swear i tried that though and it didnt work… maybe my cache tag was still active and i was just watching cached craziness. eitherway, had to set the animation speed to 0 on the noise, but it did the job.
    thanks again.
