Activity Forums Adobe Audition Keyframed notch filter?
  • Keyframed notch filter?
    Posted by Paul Roper on March 13, 2024 at 2:31 pm
    Hello,
    As you can see from this spectral pitch display, I have some audio with a background tone that rises in pitch from about 4KHz to about 6kHz over around 7 seconds. This rising tone appears in the background around 15 times in my Premiere Pro sequence. Is there way I can create some kind of keyframe-controlled, or LFO-controlled notch filter to filter out this very narrow (but rising) frequency? I have successfully used Audition’s selection tools to remove this line from the spectral display, and it sounds good, but it’ll be pretty time-consuming to do this for each time the sounds appears, so I’m hoping there might be a shortcut! Any thoughts, anyone?
    Thanks! ~ Paul
    Paul Roper replied 2 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
