Activity Forums Maxon Cinema 4D Keyframe won’t record animation?
  • Keyframe won’t record animation?
    Posted by Caroline Anthony on September 24, 2015 at 8:33 pm
    Hello everyone,
    I’m having trouble recording animation. In object mode, with the scale parameter selected, I keyframe>scale>keyframe a sphere. Keyframes show up but scrolling back and forth between them shows no animation. The sphere retains the last size I’ve scaled it to.
    Jim Scott replied 10 years, 11 months ago 2 Members · 1 Reply
  • Jim Scott
    September 24, 2015 at 9:56 pm
    I find the same situation occurring when I try to keyframe scale using the Record button. It adds a keyframe but whenever I change scale at a different point in time it just uses the same value for every keyframe. To get it to work add your keyframes using the object’s Attributes window: Command click either the Radius in the Objects menu or the X,Y,Z scale values in the Coordinates menu.
    I am no expert, so I don’t understand why the Record button is not recording the scale values. Perhaps someone else can shed some light on this.
