Activity › Forums › Adobe After Effects › Keyframe velocity gets messed up if I move a keyframe
  • Keyframe velocity gets messed up if I move a keyframe
    Posted by Blake Goulette on September 14, 2022 at 8:39 pm
    Hi all, if I adjust the keyframe velocity of a keyframe, then move that keyframe, After Effects resets at least one of its points (in or out) to 0.01 or something, regardless of what I had it set at. Why? And is there anyway to prevent it?
    While I’m here, is there any reason why I have to set separate properties differently? Meaning, if I want to set velocity for, say, position and rotation, I have to do property first, then the other.
    Blake Goulette replied 4 years ago 2 Members · 2 Replies
  • Walter Soyka
    September 15, 2022 at 4:37 pm
    I think the keyframe velocity-influence model is confusing, hard to learn, hard to use, and generally unfriendly to artists.
    My whole team uses Flow for easing:
    https://aescripts.com/flow/
    It’s a much more intuitive interface, and you can easily read, store, share, and write keyframe easings across multiple properties at the same time.
  • Blake Goulette
    September 15, 2022 at 7:36 pm
    That sounds amazing! Going to have to see if I can convince the powers-that-be that I need it! Thanks!
