Activity Forums Adobe After Effects Keyframe scale rounded rectangle from anchor point (just y axis) and not from the centre
  • Keyframe scale rounded rectangle from anchor point (just y axis) and not from the centre
    Posted by Fabian Biehne on January 24, 2019 at 9:28 am
    Hi there,
    I want to keyframe the scale of a rounded rectangle in the y direction from the anchor which I set to the bottom of the rectangle to preserve it’s roundness and so that it just grows in height. However when I change the y-size under Rectangle Path 1 > Size it still grows from the centre in both y directions (up & downwards). When I go to Transform > Scale (outside of > Contents) and change the y value here the roundness of the rectangle is distorted but the growth from the anchor point works.
    Fabian Biehne replied 7 years, 8 months ago 3 Members · 4 Replies
  • Walter Soyka
    January 24, 2019 at 11:08 pm
    Instead of using a rounded rectangle, create a path on your shape layer with two points. Add a big fat stroke, set the line cap to to Round, then use Trim Paths to extend it from a circle to a rounded rectangle.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Fabian Biehne
    January 25, 2019 at 12:35 pm
    @Dave
    I don’t exactly get what you mean. Where can I find these properties?
    @Walter
    Actually I did it this way and used a stroke.
    Thanks for your answers.
  • Kalleheikki Kannisto
    January 25, 2019 at 6:44 pm
    Walter’s is by far the simplest solution. But if you need to do this with a shape layer, you can add the following expression to the Transform Position property of the rounded rectangle. Expression assumes this is is being applied to “Rectangle 1”.
    content("Rectangle 1").transform.position+[0,content("Rectangle 1").content("Rectangle Path 1").size[1]/2]
    Senior Graphic Designer
  • Fabian Biehne
    January 25, 2019 at 6:51 pm
    Thanks for your help, guys!
