Activity Forums Apple Motion Keyframe indipendent from build in/out
  • Keyframe indipendent from build in/out
    Posted by Francesco Benciolini on November 26, 2014 at 11:16 am
    Hi, i’m trying to create a title for FCPX using motion5, the title has to be a gear rotating at 1 turn every 5 seconds, sliding in; the title appears, stays in place, then disapears and the gear slides out, i’m using build in/out markers, but the rotation speed is affected by the length of the title, how can i make it a constant? i tried to create a video of the gear rotating and then animating it but it remaps the video time.
    Francesco Benciolini replied 11 years, 10 months ago 2 Members · 2 Replies
  • Mark Spencer
    November 26, 2014 at 2:45 pm
    You need to use a Loop marker at the end instead of Build markers.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Francesco Benciolini
    November 26, 2014 at 6:31 pm
    but in this way i loose the slide out
