Activity Forums Adobe After Effects Keyframe Assistant
  • Keyframe Assistant
    Posted by Brian Hogan on September 12, 2008 at 8:39 pm
    Hi there,
    So I’m not exactly sure how this happened but the Keyframe Assistant is greyed out. I’m not exactly sure if I pressed a key command by accident or something to switch of this mode but I just find it to be kind of weird. I opened up a different AE project and I can’t access the keyframe assistant from other projects as well. I’m sure it’s a simple fix but I’m not exactly sure what to do. If anyone has an answer I would appreciate it. Thanks!
    Brian
    Brian Hogan replied 17 years, 11 months ago 2 Members · 2 Replies
  • Pat Jaeger
    September 13, 2008 at 6:20 am
    All i can suggest is that you make sure ‘caps lock’ is not on as this can pause some functions of the program. Other than that im stumped.
    Hope ive helped,
    Pat Jaeger
  • Brian Hogan
    September 15, 2008 at 2:43 pm
    yeah…the caps lock is not on and that was the first thing i checked when this happened. it’s really weird and i can’t seem to find an answer on the web or in the adobe help. if anyone else has had this problem before and knows how to fix it please let me know. thanks!
    brian
