Activity Forums Adobe Premiere Pro Keyfames slipping when moved to a different suite
  • Keyfames slipping when moved to a different suite
    Posted by Dave Vickers on September 4, 2014 at 11:28 am
    Has anybody had this problem before?
    I’ll go into some detail with the problem. Im working on a project where we animate a hand drawing an image. We have 1 layer of video that has a white background, and the image appearing on the screen, then we keyframe the hand on another layer to make it looks as if its being drawn. The hand was filmed on a green screen and we use a colour key
    As we are doing many of these there are many people working on them, so we use multiple machines. We hot-swap the drives by use of a caddie system. All suites have the same OS (10.8.4) and same version of adobe Premiere Pro CC 7.1.0
    However when we transfer to a different suite, sometimes there is a slip with the keyframes, where the hand doesn’t link up at all.
    We have 3 suites: 2 & 3 seem fine when swapping, however if we have saved a proj on suite 2 or 3, then open it on suite 1, then this error seems to occur. I have re-rendered and checked to see the project is linking up to the correct files and they are.
    I have attached an example of how the same frame looks on different suites:
    Dave Vickers replied 12 years ago 1 Member · 0 Replies
  • 0 Replies
