Activity Forums Adobe After Effects keyed comps are rendering with background color
  • keyed comps are rendering with background color
    Posted by Jason Schiedel on August 9, 2005 at 7:28 pm
    Hi everyone-
    This problem must happen all the time but I didn’t see it described in the posts. I am keying footage in AE 6.5 using keylight. I want to render the keyed character as a separate movie and bring it into another comp, but when I finish rendering, all my movies have either the background color included, or I still see the bluescreen, only with all the color drained from it (it’s black). I know I must be setting something wrong in the output module, only I’m not sure what. What do I need to do to render out the keyed footage with a transparent background?
    J
    Jason Schiedel replied 21 years, 1 month ago 2 Members · 2 Replies
  • Steve Roberts
    August 9, 2005 at 7:37 pm
    Use the Render Queue to render to a codec that supports an alpha channel, and render to millions+ colors, RGB+alpha.
    We generally recommend Quicktime’s Animation codec at 100% quality.
    Steve
  • Jason Schiedel
    August 10, 2005 at 12:21 pm
    Thankyou so much. I repeated the render over and over again while missing “A milliion colors +”. I knew it had to be something so simple and obvious!
    Best,
    Jason
