Activity Forums Adobe After Effects keyed animal needs shadow
  • keyed animal needs shadow
    Posted by Josh Coyne on August 11, 2009 at 4:40 pm
    I have keyed footage of a goat. The key is excellent, but I am having a problem adding the shadow. I have tried pretty much everything out there from adding lights, cameras, floor/ground layer, and all types of effects/filters. Everytime I end up with only one or two matching properly. But all four legs matching the composited shadow just isnt working. Any ideas?
    thanks
    josh-
    David Johnson replied 17 years ago 3 Members · 3 Replies
  • Dave Johnson
    August 11, 2009 at 8:09 pm
    Have you tried using a second instance of the keyed footage itself?
    Whether and how well this method works depends very much on the footage and background, but you could try using your choice of the many methods to fill a copy of the keyed subject footage with black, put it below the main layer, make a it a 3D layer and rotate it to where the shadow should fall, drop its opacity way down (and/or use a blending mode), add a fast blur, and add a graded mask to give it falloff.
    I hope that works for you since it sounds like you’ve put yourself through the ringer trying every other way.
  • Josh Coyne
    August 11, 2009 at 10:09 pm
    Dave, I will give it a try. I did try this first, but I kinda half assed it. Perhaps I can make it work with some effort.
    Thanks for the input.
    Josh-
  • David Johnson
    August 11, 2009 at 10:17 pm
    Glad to help, Josh. I’m sure you’d realize this, but I forgot to mention that method is more render intensive than most effects-based shadows so whether it’s useful in a particular situation also depends very much on comp size, length, machine horsepower, etc.
