Activity › Forums › Adobe Premiere Pro › Keyboard Shortcut to view clip properties in timeline?
  • Keyboard Shortcut to view clip properties in timeline?
    Posted by Paul Boone on July 7, 2015 at 1:33 pm
    Hi, I’m dealing with mixed frame rates, and I’m looking for a keyboard shortcut to easily see the properties of a clip I’m working with in the timeline, and see resolution, frame rate etc.
    Stephen Henderson replied 11 years, 1 month ago 4 Members · 4 Replies
  • Alex Udell
    July 7, 2015 at 2:04 pm
    Hi…
    Do you have your info panel exposed anywhere in your layout?
    this might help get all the info you need at any time..
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Paul Neumann
    July 7, 2015 at 2:52 pm
    I’m a big fan of the Info Panel. Can’t dock it like others though. That bugs me.
  • Alex Udell
    July 7, 2015 at 3:32 pm
    Paul…wow that is strange…
    sort of docks if it’s not the only tab in a panel…
    but put it on its own and the tab goes away…
    WEIRD…
    Alex Udell
  • Stephen Henderson
    August 14, 2015 at 2:05 pm
    I’m having the same issue, I have a timeline with lots of different frame-rates, and I need to quickly check the frame-rate of a clip.
    I tried the info panel, but for some reason it doesn’t show the fps of the clip selected, only the timeline. So if I click on a file that is 60p, the info panel will show it’s name, but incorrectly show 23.976fps.
    Anyone else have this problem? Or know of another way of telling varying frame-rate clips apart?
