Keyboard shortcut to raise and lower volume
I know about the Ctrl+ and Ctrl- shortcuts. But they only work on the entire clip you have selected. I also know you can select a range, but that’s overly time-consuming – especially when your tweaking some keyframes that already exist. And it doesn’t work so well with connected clips.
What I would like is to have some shortcut keys that work on the keyframe or segment of the volume envelope you have selected. So you can have faster, finer and more accurate adjustment than with the mouse.
I don’t think it’s currently possible. Am I missing something.
