Activity › Forums › Adobe Premiere Pro › Keyboard shortcut for soloing a single track for track targeting
  • Keyboard shortcut for soloing a single track for track targeting
    Posted by Dustin Parsons on October 30, 2014 at 5:36 pm
    Is there a keyboard shortcut that would allow me to solo one track for track targeting while turning off all others?
    Dustin Parsons replied 11 years, 11 months ago 2 Members · 2 Replies
  • Sam Lanes
    October 31, 2014 at 1:01 pm
    I had a look into something similar to this a while ago, and whist there isn’t an option to create a KB shortcut for what you require, there are some ways to do it with a couple of extra strokes.
    [Note: If you want to find out all the KB shortcut possibilities in Premiere, go to Edit > Keyboard Shortcuts and have a browse/search throught there. I have created loads of additional shortcuts after discovering them in there. It is amazing how many commands don’t have a shortcut set by default].
    In the Keyboards shortcuts panel, search “target”, and all the related shortcuts will appear.
    There are two that are set: Toggle All Audio Targets and Toggle All Video Targets. Using this shortcut will clear all the targets currently selected.
    THEN, what I did, was to add shortcuts to the “Toggle Target Video 1-8” using the number pad on the right of the keyboard. Obviously, you might have a preferred button, but I find that works well for me.
    Once this is setup, “Toggle all targets” off, select the track you want, do the edit, “Toggle all targets” on.
    https://www.aefromscratch.com
  • Dustin Parsons
    October 31, 2014 at 4:56 pm
    Yeah, sounds like that’s the best solution for now. I’ll have to put in a feature request for this. Thanks!
