Activity Forums Adobe Premiere Pro keyboard shortcut for moving clips in timeline
  • keyboard shortcut for moving clips in timeline
    Posted by Greg Jones on June 19, 2013 at 4:11 pm
    Does anyone out there know what the keyboard shortcut for moving a clip up or down a track in Premiere Pro CC is? I know it can be done, but I can’t seem to figure out the shortcut for doing it.
    Greg Jones
    D7,inc.
    Andy Edwards replied 9 years, 5 months ago 8 Members · 10 Replies
  • 10 Replies
  • Justin Crowell
    June 19, 2013 at 4:53 pm
    Same as FCP7! alt/option and arrow key!
    Editor, Producer, DP
    JustinCrowell.com
  • Brian Mclean
    June 19, 2013 at 6:59 pm
    U can also customize this in your short settings too!
  • Rupert Van den broek
    June 20, 2013 at 10:54 am
    What is this referred to in the keyboard shortcuts? I tried the alt-arrow key combination and it didn’t work and a search of the keyboard shortcut preferences in premiere didn’t bring up anything that seemed appropriate.
  • Brian Mclean
    June 20, 2013 at 3:29 pm
    It’s called slide clip selection.
    You can do a search in keyboard commands, and then type “slide”
    You should see it I there.
    Goood luck !
  • Andy Edwards
    June 20, 2013 at 4:06 pm
    You want to look for “Nudge” in your CC Keyboard shortcuts.
    Page explaining it:
    https://mediastorm.com/blog/2013/06/06/mediastorm-guide-to-nudging-in-premiere-pro-cc/
    Andy
    June 22, 2013 at 2:27 pm
  • Larry Asbell
    June 24, 2013 at 1:09 am
    Does anyone else feel that the new nudge track up and down keystroke moves audio in the opposite direction as you’d want? It seems to me that when you nudge video from V1 to V2 that Audio should move from A1 to A2. Currently when you nudge video to a higher number track, the audio goes to a lower numbered track.
  • Dazz Lombard
    March 4, 2016 at 2:21 am
    Yes… of course… Thank you buddy.
  • Kevin Carlson
    February 17, 2017 at 5:19 pm
    I know this is old, but the audio moving the wrong way is super annoying.
    Anyone found a way to change this nudge setting? Or a hot key combo?
  • Andy Edwards
    February 17, 2017 at 6:16 pm
    What version are you using? Just tested it in CC2017, latest release and do not see this happening.
    Andy
