Activity Forums Avid Media Composer keyable elements
  • keyable elements
    Posted by Sam Winchester on September 16, 2011 at 5:43 pm
    I have a bunch of keyable elements (flares, lower thirds, arrows etc) that I easily use in FCP, After Effects and Quantel just by dropping them on the top layer. When I try to use the elements in media composer they don’t key. Is it possible? Hopefully I’m just doing it wrong.
    Sam Winchester replied 15 years ago 3 Members · 4 Replies
  • Michael Hancock
    September 16, 2011 at 6:47 pm
    If they have an alpha channel, import them and set your import settings to either Alpha or Invert Alpha (probably Invert Alpha).
    Michael Hancock
    Editor
  • Sam Winchester
    September 16, 2011 at 10:38 pm
    thanks, yes they all have alpha channels I’ll try it.
  • Glenn Sakatch
    September 17, 2011 at 4:03 pm
    Do they have the “key” symbol on them when you look at them in the bin?
    If not, then you do need to re-import them with alpha invert selected in the options.
    Also, not sure if it has changed or not, but in the old days, keyable elements had to be premultiplied on black for Avid. Not sure if that has ever been adjusted or not. Keyable elements on a white background may not key properly for you.
    Glenn
  • Sam Winchester
    September 20, 2011 at 4:05 pm
    Thanks guys worked perfectly!
