Activity Forums Apple Final Cut Pro Legacy Key – gradient on subject
  • Key – gradient on subject
    Posted by Tony Van mellaert on January 29, 2010 at 8:57 am
    I just used Boris Chroma Key Studio to make a key,
    but now I want to make the subject darker gradient like
    (darker on the lower half than the top half)
    When I put a gradient on a top layer and try Composite Mode
    it also has effect on the background layer…
    How do I do this?
    Here’s a screenshot: https://www.zidazo.com/key.png
    Thanx for any tips.
    Rafael Amador replied 16 years, 7 months ago 2 Members · 4 Replies
  • Rafael Amador
    January 29, 2010 at 12:59 pm
    Hi Tony,
    With the three layers as you have, try nesting the gradient with the foreground layer.
    That way the composite mode of the gradient shouldn’t affect the background.
    rafael
    http://www.nagavideo.com
  • Tony Van mellaert
    January 29, 2010 at 4:54 pm
    That’s the trick I was looking for…
    Again a different approach than Avid, but it makes perfect sense.
    Thank you.
  • Tony Van mellaert
    January 29, 2010 at 9:08 pm
    I got an even better tip from Matt from Boris support:
    you may want to use the BCC bright – contrast filter and use the pixel chooser parameters to isolate the area you want to effect.
    Everything I wanted to do is possible with this effect,
    even the gradient.
    This is really fantastic! Thanks Matt!
  • Rafael Amador
    January 30, 2010 at 2:03 am
    Yeah, Tony, that’s great but for you as a FC editor, is more important to lear how nesting works.
    Is the way of grouping layers, and also to alter the FC rendering pipeline.
    In FC the rendering pipeline is:
    – Speed
    – Effects
    – Motion Effects
    – Composite Modes
    – Transitions.
    So if you want to, for example, apply an effect over a transition, you need to nest the transition first.
    rafael
