Activity Forums Apple Final Cut Pro Key Frame title text size
  • Key Frame title text size
    Posted by Eric Holzapfel on May 19, 2012 at 4:38 pm
    I have added a title to my storyline in FCP X. It does not seem possible to
    keyframe the text size for titles (?) What am I missing?
    I place the playhead at the start of the title, set a size – and move the playhead to end of title
    and set a larger size, but the size does not change, and no keyframe is added.
    I must be missing something.
    Eric
    Final Cut Pro, Adobe After Effects, Photoshop
    Eric Holzapfel replied 14 years, 3 months ago 2 Members · 2 Replies
  • Simon Ubsdell
    May 19, 2012 at 5:49 pm
    You don’t want to keyframe the text size as – even if it were possible – it would result in a steppy animation. The easiest way to achieve a dynamic resize is to keyframe the scale transform parameter.
    Simon Ubsdell
    http://www.tokyo-uk.com
  • Eric Holzapfel
    May 20, 2012 at 8:20 pm
    Hello,
    Thanks for the reminder! I should have thought of the scale parameter!
    Eric
