Activity › Forums › Apple Final Cut Pro › Key footage with a matte layer in FCP X
  • Key footage with a matte layer in FCP X
    Posted by Dave Jenkins on December 5, 2014 at 1:53 am
    I need to add a background to a stock footage clip.There are two clips, one with a person walking with a white background. The second clip has a black background and the person walking in white.
    How do I combine these to make a key?
    Dajen Productions, Santa Barbara, CA
    Mac Pro 3.5MHz 6-Core Late 2013
    FCP X
    Dave Jenkins replied 11 years, 10 months ago 3 Members · 3 Replies
  • Bret Williams
    December 5, 2014 at 3:25 am
    Put the matte clip above the other and set its composite mode (bottom of inspector)to stencil luma.
    Now if you want to add something as a background, place it above everything and set its mode to behind. Alternatively you could make a compound out of the first two and then put the background below the compound.
  • William Davis
    December 5, 2014 at 4:59 pm
    You can also use the Image Mask effect on your fill layer and drag the matte layer into the image well.
    Cheers,
    Bill
    Bill Davis
    thedavisreview.com
  • Dave Jenkins
    December 5, 2014 at 8:22 pm
    Thanks I’ll try both.
    FCP X
