Activity Forums Maxon Cinema 4D keeping parametrics animation and adding them specific shaders by polygons
  • keeping parametrics animation and adding them specific shaders by polygons
    Posted by Victor Camacho guerrero on December 15, 2014 at 9:44 am
    Hello!
    i have been wondering this for a while. I would love to do some parametrics animation, such as Slice from tube, or even changing just the size of a cube, but at the same time having control to change some of the polygons with a different materials, for example, selecting them and Set selection and add a material to them.
    I tried to bake the object then, but after converting to polygons the mesh loses his parametric animation.
    anyone has tried this before?
    Many thanks
    Victor Camacho guerrero replied 11 years, 8 months ago 3 Members · 6 Replies
  • Brian Jones
    December 15, 2014 at 9:28 pm
    you can keep the parametric animation by putting a Correction deformer on the object, add a Point Cache tag to the Correction deformer, Store Sate then Calculate in the point cache then you can make the object editable (or current state to object) and move the Point Cache tag from the correction deformer to the editable object.
  • Victor Camacho guerrero
    December 15, 2014 at 9:43 pm
    amazing Brian, it works great. the only thing I would say after doing Current State to object to the parametric object , then I lose the chance later on to modify again ( unless i keep a backup) the parametric animation. Is there any way for keep that?
    Many thanks!
  • Brian Jones
    December 15, 2014 at 9:56 pm
    Current State to Object does save the original, you’d have to keep that I think. You would have to reapply textures…
  • Adam Trachtenberg
    December 15, 2014 at 11:31 pm
    You actually don’t need all those steps. Just apply the correction deformer, create the poly selection tags on the deformer (give them unique names), then drag the selection tags onto the primitive object. Now drag the materials onto the primitive and assign the tags.
    That gives you polygon selections without having to make anything editable.
  • Brian Jones
    December 16, 2014 at 12:27 am
    it’s been fixed in 16? Excellent!
    December 16, 2014 at 9:55 pm
    BOOM! awesome , exactly what I wanted, this would save me a lot of work. Thanks for this guys !
    Cheers!
