Activity › Forums › Apple Final Cut Pro Legacy › Keeping Dissolves Intact
  • Keeping Dissolves Intact
    Posted by Robert Due on January 8, 2009 at 7:27 pm
    I am new to FCP (Avid user learning FCP). On the Avid, when you want to replace a shot that is bound on each side with a dissolve, you simply mark your clip, insert the new one and your dissolves stay. I am noticing in FCP that the dissolves are removed when you swap out the shot. Is there a way of doing this without having to rebuild the dissolves that were there? I can’t find anything in the user manual that explains this.
    Thanks in advance!
    Robert Due
    Editor / Colorist
    INDEPENDENT EDIT
    Robert Due replied 17 years, 8 months ago 2 Members · 2 Replies
  • Shane Ross
    January 8, 2009 at 9:00 pm
    Sorry, can’t do that in FCP yet. I remember the older versions of Avid where you couldn’t do that either. Then the Meridians came out and BOOM, dissolves remained intact.
    Hope they add this one day.
    Shane
  • Robert Due
    January 8, 2009 at 9:42 pm
    Yes, this was amazing when Avid implemented this feature. So simple, and a huge time saver. So, no way to do it in FCP? That should have been added a long time ago. I will trudge along for now.
    Robert Due
    Editor / Colorist
    INDEPENDENT EDIT
