Activity › Forums › VEGAS Pro › Keep using svp13 for subs or change?
  • Keep using svp13 for subs or change?
    Posted by Amanda Duffield on December 13, 2017 at 12:15 pm
    I have Sony Vegas Pro 13, architect 6, caption assistant, vegasaurus, handbrake.
    Today:
    I wanted to end up with an mp4 with captions burned in & coloured for different speakers and occasionally moved around the screen.
    I had some captions from you tube which needed correcting.
    They would only export in sbv format.
    None of my captioning programs could read in sbv.
    I used an online conversion to get srt .
    I imported to Vegas but wanted to change them all to bottom Centre & couldn’t figure out how to do that all at once?
    Then, I wanted to change the colours of some of them but couldn’t get hoe to do that either, even after reading the help section.
    Then I thought caption assistant would read the srt s and allow me to change them, but it only seems to read in text files, correct? It couldn’t pick up the srt S as they were in the Vegas project, or process the existing markers in the project, it wanted me to retime.
    I then converted to text using vegasaur which retained all my timings which was good but I had a lot of trouble changing thea titles&text template to suit my needs.
    Anyway I know this was way too long a process but I don’t actually know what the best process is. I have to be able to burn in but I also need to be able to edit the footage (add copyright notices and cut sections out), Plus full control of subs formatting.
    Maybe I should be doing my subs in something like subtitle edit and then burning with handbrake?
    Any suggestions.
    Thanks.
    Francois Pénzes replied 8 years, 9 months ago 2 Members · 1 Reply
  • Francois Pénzes
    December 17, 2017 at 12:47 am
    Hi Amanda !
    You may want to take a look at Caption Assistant from Vasst.
    Works beautifully.
    I am not sure if they have a ”Try before you buy” option.
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    \’\’When the cutting stops, the editing begins…\’\’
