Activity Forums VEGAS Pro Keep track of original timestamps on clip
  • Keep track of original timestamps on clip
    Posted by Austin Bauer on May 10, 2020 at 6:51 pm
    I have a job editing Twitch streams. The person who does the streams often interacts with the chat and I need to be able to figure out where in the VOD the chat message may have come in. Obviously, once I start editing the video the timestamp won’t stay the same. Is there a way for Vegas to tell me the original timestamp a clip had before I started editing it?
    Sorry if this question sounds convoluted.
    Austin Bauer replied 6 years, 3 months ago 2 Members · 3 Replies
  • Francois Pénzes
    May 11, 2020 at 1:32 am
    Hi Austin
    This is my way of doing this. (I’m old school…) First off, I re-render my footage with a time code burned in and save it under a different name. Depending on your workflow, you may want to match the time code with your time stamp. I use this rendered file as if it were the original file and start working on my edit. When everything is done and am happy with the results, I change the rendered file location (I don’t delete it yet in case I have to make changes later) and when Vegas asks for the missing file, I just point to the original file.
    Cheers !
    PC Win 10 Pro 64-bit 16gb
    Ryzen 9 3900X 12 Core 4.60GHz
    Radeon RX 5700 XT
    Cameras: Canon XF305 + Canon XH-A1 and a bunch of others
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • Austin Bauer
    May 11, 2020 at 8:15 pm
    Okay, thanks.
  • Austin Bauer
    May 25, 2020 at 4:48 pm
    Actually, I found a more effective method. I set up the timecode in a slim track just above the footage and group them all together with the G key. Then I just delete that layer when I’m done. Don’t know about others but it works for me.
