Activity Forums Adobe After Effects Keep text field out of effect controls in Premiere
  • Keep text field out of effect controls in Premiere
    Posted by Lee Pines on December 20, 2021 at 10:58 pm
    I’m making an acronym element and I want two text fields to be the same text (in the image this would be the letters. In Premiere in the effect controls panel, I want to have only one field so that my teammates won’t be confused as to which one to use. I already set up the script so that the text is copied from one layer in After Effects. How do I keep the other text layer from showing up in Premiere’s effect controls?
    I tried putting it in a precomp, but it still shows up. Is there another way?
    Graham Quince replied 4 years, 8 months ago 2 Members · 1 Reply
  • Graham Quince
    December 22, 2021 at 9:45 am
    In After Effects, expand your two text layers so you can see the Source Text property. Then use a pickwhip to link the second to the first. Whatever text appears in the first text will appear in the second.
