Activity Forums Adobe After Effects Keep Motion From Parent After Parents Deletion
  • Keep Motion From Parent After Parents Deletion
    Posted by Andy Baumgartner on February 3, 2011 at 8:10 pm
    Hi, I’m using a null’s rotation to animate the parabolic path of a ball. I’d like the ball to bounce which requires I rotate around a new axis.
    Is it it possible to “expand” the rotation data of null into rotation and position for the ball?
    Tudor “ted” jelescu replied 15 years, 7 months ago 3 Members · 2 Replies
  • Olin Padilla
    February 3, 2011 at 9:08 pm
    If I’m following you correctly, you’re ball is parented to a null and offset so that when the null rotates the ball moves in an arc, right?
    Personally that doesn’t sound like a great way to do it. First of all, those arcs will not be parabolic, just round. Second, what’s so hard about using position keyframes? Using bezier curves with handles, you can basically draw a path with way more control then your current method.
    Unless I missed something.
  • Tudor “ted” jelescu
    February 3, 2011 at 9:24 pm
    Or you can try doing it with expressions. Here’s a thread from the Cow where you can find the expression scripts and explanation:
    https://forums.creativecow.net/thread/227/8214
    Tudor “Ted” Jelescu
    Senior VFX Artist
