Activity Forums Adobe After Effects keep effect inside the layer
  • keep effect inside the layer
    Posted by Paulo Cézar Junior on March 19, 2021 at 2:12 am
    I’m from Brazil and I speak Portuguese. Perhaps the translation can get in the way and not be understood. See the attached image. I have this sound bar effect. I want to reduce this circle of sound bar, but I don’t want it to happen what I pointed with my finger, it is square, because the effect is only within the limit of the layer. Any suggestions on how to resolve this.
    I want to reduce the circle but the effect is normal and not limited to reduction. In this case, I used scale, but I couldn’t find any other way to do it. See the draft image
    Graham Quince replied 5 years, 5 months ago 2 Members · 2 Replies
  • Paulo Cézar Junior
    March 25, 2021 at 11:46 am
    <font style=”vertical-align: inherit;”><font style=”vertical-align: inherit;”>??? Help-me!</font></font>
  • Graham Quince
    April 2, 2021 at 11:34 am
    Instead of using Polar Coordinates, use a circular mask with your Audio Spectrum, you can then keyframe the mask’s path for the size change.
