Activity › Forums › Adobe Premiere Pro › Keep clip frame rates interpreted after reconnect?
  • Keep clip frame rates interpreted after reconnect?
    Posted by Mark Rathgeber on February 17, 2014 at 2:31 am
    For my work I’m having to collaborate with another editor living in another city. We both finally decided to make the switch over to Premiere (we had been using Final Cut Pro X until now, but I’ve been using FCP since version 3). Anyway, one problem I’ve been having is when I send a project file over to him, when he tries to reconnect the footage, he has to re-interpret all the clips that I’ve changed the frame rates to. I remember this being a problem with FCP7 and earlier versions as you would need to use Cinema Tools, but FCP10 managed to integrate this feature into the actual software. You could even export an XML with the metadata included –one of the few things it actually did well.
    Does anyone have any idea how I can keep this metadata within the project so that he or I do not have to reinterpret the footage every time?
    Mark Rathgeber replied 12 years, 7 months ago 2 Members · 2 Replies
  • Vince Becquiot
    February 17, 2014 at 3:21 am
    Hi Mark,
    Make sure you select “Preserve interpret footage settings” when relinking, it’s unchecked by default on the right side of the locate window.
    Cheers,
    Vince
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
  • Mark Rathgeber
    February 17, 2014 at 3:37 am
    You are a gentleman and a scholar!
