Activity Forums AJA Video Systems KBox w/Kona 2 vertical breakup in playback…
  • KBox w/Kona 2 vertical breakup in playback…
    Posted by Tim Baker on December 27, 2005 at 10:58 pm
    Hey all,
    I have the Kona2 with the Kbox…when I digitize footage from my HD100 and try to playback via Final Cut ProHD there is vertical breakup in the video. I am having to do a downconvert to playback as I do not have the money for an HD monitor system yet…I am using a Sony trinitron and the component hookup from the Kbox.
    It used to playback clean, but now something has changed and I can’t figure what it maybe. I had to rebuild my system with clean install because the auto update from Apple fried everything. I did all the current dloads from Aja.com and now I have this problem.
    Is there a Control Panel that I am not finding for the Kona2 and/or Kbox? Because I would like to test it via that, cause none of the settings that I pick in FCP are working properly.
    Help!!!!!
    Thanks all,
    Tim Baker
    Chameleon Mobile Video Productions
    (239)849-3295
    “It is not the light at the end of the tunnel that we should seek…it is the courage to take the next step in the dark that we must find.”
    Bob Zelin replied 20 years, 9 months ago 2 Members · 1 Reply
  • Bob Zelin
    December 28, 2005 at 3:53 am
    It’s called Kona Control Panel, and it downloads along with your Kona 2 drivers. It’s in your application folder. Go to http://www.aja.com, go to support, and download the latest AJA Kona 2 drivers, and you will have the Kona Control Panel (which also affects the K Box).
    Bob Zelin
