Activity Forums Adobe After Effects Kaleidescope effects, multiplying people/objects
  • Mylenium
    November 29, 2006 at 7:16 pm
    What are you looking for? There is no magic there. It’s all just multiple shots in multiple passes combined with each other. The intel ads use motion control cameras, most likely. Even without such extra equipment, it’s more a matter of planning the shots than execution in compositing. They key factor simply is figuring out how you want to “stack” your stuff in the scene and then shoot it accordingly. Once you have your footage keyed and cleaned up, you simply pop it on 3D layers and place them where you want them. Obviously you should have some storyboard or pre-viz to get it all together.
    Mylenium
    [Pour Myl
