Activity › Forums › JVC Cameras › JVC’s GY-HD110U Capture with other Camcorders
Posted by Joaquin Ruano on July 16, 2008 at 6:10 pmi shot some footage with JVC’s GY-HD110U, but that camera was rented and it was very expensive, for the capture im can get other hd cameras for free, but i have having trouble capturing or reading the tapes.
my question is: is it posible to capture material shot with this camera using another brand camera or deck and if so which is it.
thanks
joaquin
Claes Lilja replied 18 years, 1 month ago 3 Members · 15 Replies -
Chris Borjis
July 16, 2008 at 11:42 pmSony HDV decks will play the JVC Tapes in 30p and apparently 24p will also capture but you will not see it on the lcd.
Joaquin Ruano
July 17, 2008 at 3:42 ami tried on a sony deck and could not read it and also tried on a canon xl and could not even play it on its play back.
any body else got any sugestionsthanks for the response Cris
Chris Borjis
July 17, 2008 at 7:56 pmyou played HD110 recorded HDV tape to a Sony HDV deck and it didn’t work at all?
It definitely should, are you sure it was set for HDV?
The Auto setting does not work well on the sony HDV decks. -
Claes Lilja
July 21, 2008 at 10:38 pmI have a similar issue that I am dealing with. I am trying to capture JVC footage with a Sony deck into FCP. I see the timecode, but the screen stays black.
Chris Borjis
July 22, 2008 at 7:14 pmdid you go into the sony deck menu and switch
the DV/HDV switch to HDV?if its on AUTO it will not work.
Claes Lilja
July 25, 2008 at 3:08 amYes, I set the switch to HDV. I am able to capture footage shot on my Sony V1U in 1080i without any problems. When I put the tape with the JVC footage in the deck, it will play out to the monitor connected directly to the deck, but in my FCP Log and Capture window I only have a black screen. I do see the timecode and I can still control the deck from the L&C window within FCP.
Chris Borjis
July 25, 2008 at 4:27 amare you connected via firewire?
I have not tried that, but I know the component outputs should work if you have an aja or black magic capture card.
Claes Lilja
July 25, 2008 at 9:59 pmI am connected via firewire. Not sure what is in the computer. I’m on the 2.8GHz Intel Core 2 Duo iMac.
Chris Borjis
July 28, 2008 at 10:42 pmah, thats why its not working.
you might have to find someone with that deck and provide
a hard drive to capture to.I have one, but I’m in Oregon.
Claes Lilja
July 28, 2008 at 11:19 pmI was hoping to avoid that. So the issue is with the iMac hardware not being able to process the signal through firewire?
