Activity › Forums › JVC Cameras › JVC ProHD camcorder output to SDI
  • JVC ProHD camcorder output to SDI
    Posted by Eddy Pribeagu on March 3, 2010 at 9:54 pm
    Hi… im currently using JVC ProHD camcorders ( GY-HD110 ) and if anyone can help on what is the best way to get an output to SDI… The outputs on the camcorder now are only IEEE 1394/HDV/DV , component , and composite. Im planning on filming in 720p and the feed will be sent to a video mixer via SDI… thanks for any help!
    Mark Petereit replied 15 years, 10 months ago 4 Members · 12 Replies
  • 12 Replies
  • Piotr Niemcewicz
    March 4, 2010 at 7:57 pm
  • Mark Petereit
    March 5, 2010 at 12:16 am
    I have that exact camera and use the BlackMagic Analog to SDI miniconverter. Works flawlessly!
    And at $470, it’s about $500 cheaper than the AJA.
    Mark
  • Eddy Pribeagu
    March 5, 2010 at 2:36 am
    Thanks alot guys.. but i was also wondering if i would get better quality converting HDV through the IEEE 1394 port to HD-SDI, since there both digital, instead of from component… what do you guys think?
  • Mark Petereit
    March 5, 2010 at 11:25 am
    You DEFINITELY want to convert from the component out — it’s uncompressed analog. If you go Firewire out, your video is going to get reduced in quality a bit due to the HDV compression and it will come out with a significant delay.
  • Eddy Pribeagu
    March 5, 2010 at 2:55 pm
    Thanks alot!.. thats the answer i was looking for..
  • Piotr Niemcewicz
    March 5, 2010 at 7:31 pm
    only component!!!
    by firewire reduced color sample rate to 4:2:0 (pal) and bit rate reduced to 19 Mbs, and imposition HDV codec (terrible)
    by component (analog or digital) you have color sample rate 4:2:2 (broadcast) full band of quality, and NO codec.
    After converter you should be connect to NANO Flash.
    https://www.convergent-design.com/
  • Mark Petereit
    March 5, 2010 at 10:26 pm
    Wow! $2895 for a Nano Flash? You could buy a whole Mac Pro workstation for that. 😉
  • Piotr Niemcewicz
    March 6, 2010 at 8:57 am
    you lucky man
    only 2895 $..
    in Europe + 22% VAT and $$ for duty
  • Mark Petereit
    March 6, 2010 at 3:16 pm
    I don’t know why you put up with that. But then I guess we Americans have a reputation for “handling” out of control taxes. 😉
  • Piotr Niemcewicz
    March 6, 2010 at 5:52 pm
    yes i know 🙂
    smart guy
