Activity Forums Avid Media Composer JVC HDV @ 720p – How to capture in XpressProHD 5.2.4?
  • JVC HDV @ 720p – How to capture in XpressProHD 5.2.4?
    Posted by Roc Barbanica on May 14, 2006 at 4:52 pm
    I shot with my JVC GY-HD100U @ 720p 24p. I also have the HDV deck BR-HD50U to ingest into my Avid.- No mojo, by the way- firewire only. System- XP pro on a dual Xeon w/ 4 GB RAM, 5 TB storage-
    Now, how the heck do I get my footage into Avid???
    Please- $20.00 to whomever gets me through this – I SWEAR!
    Roc-
    Mark Burton replied 20 years, 3 months ago 3 Members · 8 Replies
  • 8 Replies
  • Alex Alexzander
    May 14, 2006 at 7:45 pm
    Are you new to Avid? Do you know how to setup a deck?
    -Alex
  • Alex Alexzander
    May 14, 2006 at 8:07 pm
    Go to the Project window, and choose the Settings tab.
    Double-click the Deck Configuration setting to open it.
    1. Click Add Channel
    2. Set Channel Type to FireWire
    3. Set Port to OHCI
    4. Select OK
    5. When prompted to auto-configure the channel, click, No.
    6. Click on Add Deck
    7. Under Devices, select JVC
    8. On the right-side of Devices, select BR-HD50U
    9. Click on the OK button at the bottom
    10.Click on Apply in the Deck Configuration window
    Use the keystroke, CTRL+7 to open the Capture Tool
    -Alex Alexzander
  • Roc Barbanica
    May 14, 2006 at 8:45 pm
    Nope- Not new to Avid and the deck works fine when in DV mode- not when in HDV-
  • Alex Alexzander
    May 14, 2006 at 8:57 pm
    And you created the correct project type?
    May as well list what you have tried.
    -Alex Alexzander
  • Roc Barbanica
    May 14, 2006 at 9:21 pm
    Yep- Project type is good-
    Can’t get the Avid to recognize the deck when it’s in HDV mode.
    Any ideas?
  • Alex Alexzander
    May 14, 2006 at 9:37 pm
    I did a search on the Avid forums using this text, “HDV deck BR-HD50U”.
    It turned up interesting comments. At this point, I’d say contact JVC, and post this on the Avid-L2, and the Avid Forums.
    Avid-L2
    https://groups.yahoo.com/group/Avid-L2/
    Avid Forums:
    PC: https://www.avid.com/exchange/forums/14/ShowForum.aspx
    Mac: https://www.avid.com/exchange/forums/42/ShowForum.aspx
    -Alex
  • Roc Barbanica
    May 15, 2006 at 5:05 am
    Thank you, Alex. I appreciate your staying with me on this- I’ll let you know what I find.
    Rocky-
  • Mark Burton
    May 15, 2006 at 6:30 pm
    I believe this JVC format is not yet supported by Avid Xpress Pro / MCA.
