Activity › Forums › Apple Final Cut Pro Legacy › JVC GY-HD110U to FCP 5.1
  • Walter Biscardi
    May 13, 2007 at 5:30 pm
    Have you searched this forum at all for that camera? I know there’s been a lot of discussion about JVC cameras and captures to Final Cut Pro.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Z.man99
    May 13, 2007 at 7:28 pm
    it wont work if you shot HDV, the FW port is for DV only. i have the same camera and had to buy the deck which to be honest is well worth it. the deck will only do the JVC hdv but will play any DV.
    Thanks a lot,
    andrew
  • Tom Wolsky
    May 13, 2007 at 8:08 pm
    Wrong. You can capture from the camera’s FireWire port to FCP, if you’re using a supported format with a version of FCP that works with it.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Edward Fox
    March 6, 2008 at 6:06 pm
    Tom: Please describe how to do it then. I was using the same camera and had the same problems this poster had. I could not get FCP 5.1 to recognize the camera. Was beginning to think it was a compatibility issue. My buddy’s got FC Express 4, and the camera WAS seen. My FCP 5.1 is older. I double checked the connections, the settings, everything. Please advise.
  • Tom Wolsky
    March 6, 2008 at 8:00 pm
    What did you shoot with the camera? What format and specification exactly? It can shoot different things. Only the one correct setting will work. We use the HDV 720p30 sequence preset, the HDV capture preset, and the HDV FireWire preset for device control.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Edward Fox
    March 6, 2008 at 9:06 pm
    I shot HD and 24 frame rate. I changed the Easy Setup in FCP, and my sequence settings to be the same (720p24). I suppose it’s possible that I’m overlooking something…??
  • Tom Wolsky
    March 7, 2008 at 5:08 am
    I don’t believe 720p24 was supported until FCP6.
    All the best,
    Tom
  • Dwayne Fisher
    December 7, 2009 at 8:38 pm
    Hi Tom,
    I tried employing your settings for capture [Sequence Preset HDV – 720p30, Capture Preset HDV, Device Control Preset HDV FireWire] to FCP 6.05 and it did not work for footage I shot in HDV with a JVC GY-HD110U camcorder using the following settings:
    —-Video Format——
    Frame Rate 60/30
    REC – HDV-SD60P
    Is there a different setting? What step did I miss? Should I be recording HDV-HD30P?
    Dwayne
  • George Strother
    December 9, 2009 at 1:34 am
    —-Video Format——
    Frame Rate 60/30
    REC – HDV-SD60P
    HDV – SD60p is a wide screen SD format, not an HD format. For HDV you can choose 720p30 or 720p24. Those are the only HD choices on an HD110U.
    George
    Light Images
