Activity › Forums › VEGAS Pro › just wanna print from timeline
  • just wanna print from timeline
    Posted by Al Kohout on December 30, 2005 at 6:37 pm
    Velocity does it…Premier does it…does VEGAS?
    I want to print to DV tape from the timeline..by hittign space bar or whatever..something simple..crash printing to tape…
    how do I do this without having to render the entire 2 hrs of video? I have vegas 5
    Edward Troxel replied 20 years, 9 months ago 2 Members · 1 Reply
  • Edward Troxel
    December 30, 2005 at 6:54 pm
    The PROPER way is to go to Tools – Print Video to DV Tape. And, yes, it will render all sections that need to be rendered (note: it’s only the sections that NEED to be rendered) and render the audio to a W64 file.
    If you don’t mind the sutters when it can’t keep up, simply playing back the timeline with external preview turned on will give you the video. If you run audio out from your sound card and into your recording device, you can get audio as well. However, it won’t be anywhere near as good as Tools – Print Video to DV Tape.
    If you have a DV-AVI file and simply want that on tape, try using the printing fuction in the Capture program. Or you can put it on the Vegas timeline, choose Tools – Print Video to DV Tape, and all it will do is create the W64 file (as nothing will NEED to be rendered) which is a very quick process.
    Edward Troxel
    JETDV Scripts
