Just to understand the easiest way how to compose a footage with black bacground with an other background
Hi guys,
great to be here. I’m just asking for sake of understanding. I have a very tedious project and I using Sony Vegas PRO 12, where I first had to prepare the green box files to work with, which really was a “pain in the ass”.
The green screen shots were very uneven, lots of shadow, wrinkles, different shades of green. Total shots with other elements in it. So I had to mask it and keyframed it as well. I really got it with different tools from BCC to Sony’s own plugins and one footage I had to even cut out in After Effects.
BUT just to understand.
When I have my footage A with already a black or white background and I use any of the composite modes from add, multiply to whatever to put my footage in front of an other footage B, so I will not get a result as I would, when using a green background (solid green media) for the first footage A and then using the chroma key. Is this correct ?
Sorry, it may be a bit confusing and also my English it may be a bit sluggish (German ;-).
I try to say it differently.
1. When preparing my footage the client sent to me, I used for some just a mix of differnt plugins to get rid of the green background. The result was a footage with only the actor and the background in black (I tried to put a white background underneath) . In this case the “black” was transparent. So I could use it directly with another background footage.
2. BUT, when I would render the footage with the black/white background and insert it in a new project and try to put an other background underneath of the first footage, I will not get the same results, cause the “black” will not act as it would be “transparent”.
And no composite modes will work to geht the same results like in the 1. example.Is that correct ? Or I’m missing something ?
Or is there a way that I have not discover yet ?
Thank you very much and have a nice day.
Greetings from Germany
Richard
