Activity Forums Apple Final Cut Pro Legacy just received footage i need to edit into another music video – do i need to transcode this for FCP7?
  • just received footage i need to edit into another music video – do i need to transcode this for FCP7?
    Posted by Raju Bhai on December 26, 2014 at 1:54 am
    the specs are:
    DV 720×576 (768×576 actual), millions
    16-integer
    25 fps
    This footage came from India. I imagine this is probably PAL.
    I’m wondering if i need to transcode this before editing in FCP7. If so then I will use compressor…i imagine the DV PAL setting?
    thank you
    Shane Ross replied 11 years, 8 months ago 2 Members · 1 Reply
  • Shane Ross
    December 26, 2014 at 4:06 am
    Should be fine as is…DV/PAL. Bring it in and drag it into a new sequence and you should be good to go.
    Shane
    Little Frog Post
