Activity Forums VEGAS Pro just installed Vegas Pro 10
  • just installed Vegas Pro 10
    Posted by Charles Martin on November 18, 2010 at 9:50 pm
    i’ve decided to go with the new Vegas pro 10 and take advantage of the upgrade offer.
    I had Vegas Pro 9e.
    no problem downloading but I automatically assumed that it would just replace the old version… I should have thought that one through…anyway—-i now have Vegas pro 9e and Vegas Pro 10a on my computer—-
    Do I just now uninstall the older version? No issues with losing old timelines… I see that they are all stored somewhere else and when I open Vegas pro 10 I can access them..
    but just want ot be sure nothing catastrophic will happen if i uninstall Vegas Pro 9e now…
    apologies if this is a daft question..
    Charles Martin replied 15 years, 9 months ago 2 Members · 2 Replies
  • John Rofrano
    November 18, 2010 at 9:55 pm
    To answer your question directly… it is perfectly safe to uninstall Vegas Pro 9.0 but I wouldn’t do it just yet. I would keep both versions for a little while until you are comfortable with the stability of Vegas Pro 10 on your system. You may run into a bug and have to go back to 9 for something… you never know. They both live quite happily together and I collaborate with other editors and keep several versions of Vegas on my system so that I can be backward compatible with them.
    One thing to keep in mind is that projects are not backward compatible so once you save a project in 10 you cannot open it in 9. I would save off a final copy in 9 under a new name before continuing to work in 10 on a project.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Charles Martin
    November 18, 2010 at 9:59 pm
    many thanks for this…. ideally what I wanted to do but wasn’t sure if it would cause conflicts…
    much appreciated the quick and useful response…
