Activity › Forums › Blackmagic Design › Just got a dell 24”on the MBE – looks epic -but no analogue out
  • Just got a dell 24”on the MBE – looks epic -but no analogue out
    Posted by Miles Blow on July 14, 2006 at 9:08 am
    Hi Guys
    it’s all working great …..hd playback in prem2/AE7 out to dell 24 inch, but I was hopeing it would be able to show us the footage down converted to pal at the same time on our trinatron via s-video. Is this possible or ,is it either one or the other, dvi or analogue down conversion.
    Miles
    Miles Blow replied 20 years, 2 months ago 2 Members · 3 Replies
  • Miles Blow
    July 14, 2006 at 1:43 pm
    woops had the wrong cord pluged in …….it works fine!
    thanks
    Miles
  • Chris Borjis
    July 14, 2006 at 4:10 pm
    would you share what you did to make it work?
    I have the dell 24″ as well (good choice btw!) and I want
    to see HD on it and hardware downconverted SD on our
    sony sdi crt monitor.
    the notes i have from kristian are:
    Turn on hardware down conversion and use the SDI B output to connect to the SD monitor. This way, you can monitor SD via SDI and HD via DVI.
    I did this, but all i see is pink snow on the sd monitor.
    How did you do it?
  • Miles Blow
    July 15, 2006 at 2:52 am
    Hi Borjis
    Yes the dell 24″ with the mbe definatly rocks!
    Well if I had the cords in the correct way in the first place(I am using hosa bnc to s-video breakout cable) in prempro2, AE, deckcontrol. So mac/pc drivers might work differently.
    I think all I really did was have hardware down conversion activatled and working(without the dell). Then power off, turn everythink off.
    Then plug the dell into the MBE dvi output.
    Then turn on dell,
    -turn on multibridge,
    -turn on computer .
    Then if it doesnt work once your in your edit programe then restart it and try again. I think compared to our little (pvm14 n6a) trinatron the dell looks 100 times better….unfortunatly I dont know what is more accurate. I suppose you would need to get it to look good on both. I havent played with any dell calabration yet.
    Also 2k wont do down conversion from a 2k project but both 2k and 3k files work in a hd project. We have tested it but of coause our onboard raid cant play it back properly. Hd 1920×080 50i is fine. Our poard is a asus a8n32.
    Sorry I’m rambling but hope this info can help in someway.
    Miles and Jules
