Activity › Forums › Apple Final Cut Pro › Just double checking: there’s no way to have it play at less than normal speed, correct?
  • Just double checking: there’s no way to have it play at less than normal speed, correct?
    Posted by Noam Osband on February 26, 2018 at 5:58 pm
    I’m writing a script and using footage in a FCP X project. I want to let it play and transcribe that way. However, at normal speed, the talking is too fast. I’ve custom speeded all the clips to 80% but that makes it a bit wonky and it does weird things (like insert gaps in odd places). The idea would be playing it back at less than normal speed, but I can’t see anyway to do that. Am I wrong here? Is there a way to do that?
    Brett Sherman replied 8 years, 6 months ago 6 Members · 7 Replies
  • 7 Replies
  • Steve Connor
    February 26, 2018 at 6:15 pm
    Duplicate your project then make all the clips in that project into one compound clip then you can retime that single compound clip. Make sure you tick “preserve pitch” in the retime dropdown
    \”Traditional NLEs have timelines. FCPX has storylines\” W.Soyka
  • Jeremy Garchow
    February 26, 2018 at 7:03 pm
    If you press and hold ‘l’ to play forward, and then hold k, it plays back at ~50%.
    You will need to be an octopus if you have to type at the same time.
  • Noam Osband
    February 26, 2018 at 7:07 pm
    Sadly, I am not an octopus….
  • Mark Suszko
    February 26, 2018 at 9:10 pm
    Hey Noam;
    Another way to get your transcripts, sans tentacles, is to export a low-rez of the whole timeline to YouTube, marked as “unlisted”, and let their AI transcribe it for you in a few minutes. Download the transcript, erase the YouTube, apply the transcript to whatever other process you need. If the audio is clean and clear, the quality level is pretty good.
  • Noam Osband
    February 26, 2018 at 11:23 pm
    All good advice! Thanks gang…..
  • Chad Greene
    March 1, 2018 at 11:20 pm
    I am guessing you are transcribing this yourself because you don’t want to spend money? We do a ton of transcription and have found Rev.com to be a fantastic service for a ridiculous price. $1 per minute ($1.25 with timecode) and super fast turnarounds.
    Chad Greene : Mahoney Media : Minneapolis, Minnesota : 2×2.66 GHz 6-Core Intel Xeon, 12GB Ram, OS 10.11 FCPX, Kona-LHi
  • Brett Sherman
    March 10, 2018 at 2:38 pm
    I used to use Rev.com until I got onto SpeedScriber. Speedscriber is 100% automated and Rev.com is automated then corrected by a human. So it depends on how much accuracy you need, how good the audio quality is, how fast of turnaround you need, and how integrated into FCP X you want the transcript.
    PROS
    Rev.com – More accurate, better for poorer quality audio, better for strong accents
    Speedscriber – Turnaround in minutes, integrated with FCP X so faster to work with once you have the transcript
    Brett Sherman
    One Man Band (If it\’s video related I\’ll do it!)
    I work for an institution that probably does not want to be associated with my babblings here.
