Activity Forums Boris FX Particle Illusion June Emitter Library released
  • June Emitter Library released
    Posted by Alan Lorence on July 7, 2005 at 7:25 pm
    I’ve finally released the June emitter library. Big thanks to Dan Wilcox for submitting some nice emitters that gave me some inspiration.
    Note that this library is larger than many of the others because it uses several largish image sequences. I typically avoid image sequences because I know that large libraries cause more problems, load more slowly, etc.
    https://www.wondertouch.com/downloads.asp#IEL
    I think I made some pretty good flame emitters this month. Remember when an emitter name contains “(mb)” it’s meant to be viewed with motion blur. If it contains “(mb+)”, that means use motion blur, with a higher number of blur frames (like 8 or more).
    Alan.
    wondertouch
    Shadu replied 21 years, 2 months ago 2 Members · 1 Reply
  • Shadu
    July 12, 2005 at 2:35 pm
    WOOWWW!!!! I like them all. ery good library. You can keep the size of the library that high if all the emitter are this quality.
    By the way how are done the image sequence used in these emitter?
    Shadu
