Activity Forums Apple Final Cut Pro Legacy Jumpy Video???
  • Posted by Trevor Ambrose on June 10, 2010 at 10:15 pm
    Hey Guys,
    Here’s my deal. I just got a new Mac Pro Tower with Dell 24″ ultra sharp monitors. I’ve test it by running FCP files from former projects. The video appears to be every so slightly and intermittently jumpy. Like it misses a frame or two or perhaps speeds up momentarily. It especially happens when people move a bit quickly or the camera pans or moves.
    Any ideas???
    Thanks dudes,
    Trev.
    John Fishback
    replied 16 years, 2 months ago
    3 Members · 4 Replies
  • Michael Gissing
    June 10, 2010 at 11:37 pm
    [trevor ambrose] “Any ideas???”
    Any relevant info like codec you are playing, OS, FCS version, drives you are playing off, RT settings, do sequence & easy setups match files, rendering bars?/???
  • Trevor Ambrose
    June 11, 2010 at 4:25 pm
    Nice brain storming Michael. Gives me lots of ideas to try.
    Trevor Ambrose
  • Trevor Ambrose
    June 11, 2010 at 4:29 pm
    Hi Dave,
    I’m coming out of the DVI ports which I believe should be stable. I’m going to try other ways to connect to the monitors to see if it is in fact the DVI card.
    Thanks for your help. Much appreciated.
    Trevor Ambrose
  • John Fishback
    June 11, 2010 at 7:42 pm
    Are you monitoring on an external broadcast monitor? If so, which one and what I/O card or device are you using?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
