Activity Forums Apple Final Cut Pro Legacy Jumping images in Cross Dissolve. Why does this happen…HELP!
  • Jumping images in Cross Dissolve. Why does this happen…HELP!
    Posted by Simon Malcolm on August 14, 2006 at 8:58 am
    Hi there, I have placed a series of TGA images in my timeline and keyframed them so they drift, a bit like the Mac screen saver images. I am noticing that when I apply a Cross Dissolve, or even just manually adjust the opacity to effect a dissolve, that the image will jump up and down a little bit over a couple of frames. As you can imagine it is really frustrating to see this jump in the middle of a beautiful, smooth key frame and blurry cross dissolve. Why is this happening? What am I doing wrong? Thanks for your help, Simon.
    MemoraMedia – Using media to celebrate your memories
    Chris Borjis replied 20 years ago 5 Members · 5 Replies
  • Thaxter Clavemarlton
    August 14, 2006 at 12:58 pm
    Did you RENDER these effects?
    You must render all effects at highest quality for them to look their best on-screen.
  • Mark Maness
    August 14, 2006 at 3:51 pm
    I’m sure why this happens but… every now ant then I get the same error with standard video and yes… it is rendered. As a matter of fact, it always occurs after the video is rendered for me.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Chris Borjis
    August 14, 2006 at 4:17 pm
    We just had to deal with this last week.
    The solution was to make sure the pictures were as close to D1
    resolution as possible.
    We ended up putting all the pictures scaled (with photoshop) into
    a 720×540 photoshop file then exporting them .tga then re-laying them
    back into final cut.
    The really lame part is, without the cross disolve it actually looks fine.
    I REALLY wish apple would fix these bogus f/x plugins that come with final cut. A lot of them are pretty useless and these are basic things that ANY other editing software can handle with ease.
  • Ron James
    August 14, 2006 at 6:00 pm
    Does this happen when you keyframe the dissolve? I don’t think I’ve used the stock dissolve filters since v.1 or 2. Never did like them, except for rough offline work. I’m guessing you wouldn’t have this problem with keyframes?
  • Chris Borjis
    August 14, 2006 at 7:47 pm
    just standard non-additive dissolves.
    all we use really. cuts and dissolves.
    we also tried setting the opacity from the start and end but fcp will not do opacity on a targa frame. it has to be video…..another bug imo since every other nle can do that.
