Activity Forums Maxon Cinema 4D jukebox bubbles
  • jukebox bubbles
    Posted by Richard Quinn on June 24, 2009 at 12:12 pm
    I am making a 1950’s jukebox. The jukebox has glass tubes running around the side and top in an arched shape.
    I want to animate bubbles going around the tubes.
    I was going to simply attach spheres with a glass material to a align to spline tag, with “after-repeat” selected in animation f track so my bubbles loop around.
    The animation will run for about 20 seconds so how would I go about creating about 100 bubbles following each other around an arch shape with an even spacing?
    Cheers,
    Rich
    Richard Quinn replied 17 years, 2 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    June 24, 2009 at 4:15 pm
    If you have MoGraph you could just clone onto the spline and animate the offset. If not, duplicate your animated sphere and then manually offset the tracks in the timeline.
  • Richard Quinn
    June 24, 2009 at 5:55 pm
    Hi Adam,
    I went the Mograph way……it worked a treat!
    Cheers,
    Rich
