Activity Forums Adobe Premiere Pro JPG’s in timeline randomly glitch in export
  • JPG’s in timeline randomly glitch in export
    Posted by Anthony Bernard on July 16, 2013 at 11:45 pm
    So I am cutting a feature documentary and am having a problem with pictures I have in my timeline. I have a bunch of hi-res jpegs the director scanned in for me. I have some motion/scale keyframes on them. For some reason when I do an export random pictures will glitch out. I will get vertical bars (green/white mostly) instead of the image. The motion is there, but the image itself is glitching. If there is video under the photo I can see through part of the glitch to the video as well. Its very strange and seems to have no rhyme or reason that I can see. I thought maybe it was issues with the render files so I deleted them all and tried an export again and had the same issues. I have re-rendered sections and re-exported and it will be fine then like 2 or 3 exports later that same image will glitch on export even though I made no changes to it. I’ve used JPG’s before with no issues, but should I be using a different format with Premiere? Any insight will be greatly appreciated. Thanks!
    Dave Morrison replied 13 years, 1 month ago 3 Members · 2 Replies
  • Ann Bens
    July 17, 2013 at 5:28 pm
    If you have a nvidia graphicscard roll back a driver < 320
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Dave Morrison
    July 18, 2013 at 3:31 pm
    Make sure that the scans you received are not larger than 4000 pixels along the long side of the photo.
