Activity › Forums › Adobe After Effects › jpeg sequence
  • jpeg sequence
    Posted by Hope Holmesby on July 23, 2011 at 3:05 pm
    Hi there. Thanks for reading this.
    By accident, had dragged a folder into AE and it gave a wonderful window:
    it asked me how long I wanted each layer to be and how to overlap them in a slideshow. (like the option ‘sequence layers’) but it was all in one window.
    Then it just put all layers in the comp sequenced and was done.
    Does anyone know how to get that window again?
    It did it on import.
    What do you think?
    Thanks so much.
    Warmly,
    Hope
    __________________________________________________
    Life is here to enjoy.
    Dual 1.8 GHz PowerPC G5, 150 GB; Mac OS X (10.4.11) 4GB RAM; 2 La Cie external HDs 1TB each; STP v2.0.2; FCP 6; AE 8(CS3)
    Hope Holmesby replied 14 years, 8 months ago 3 Members · 4 Replies
  • Barend Onneweer
    July 23, 2011 at 3:37 pm
    Well, you can select multiple files in the Project Window and drag them onto the ‘new comp’ button in the bottom of the Project Window.
    Raamw3rk – digital storytelling and visual effects
  • Adam Taylor
    January 25, 2012 at 10:13 am
    i think you are describing the “Sequence Layers” option, found under the Animation/Keyframe Assistant menu dropdown.
    To use it, you highlight a range of layers in the timeline, and choose the option. One thing to bear in mind is that the order you select the layers determines the which layer starts the sequence.
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
    My YouTube Animations Page
  • Hope Holmesby
    January 25, 2012 at 6:07 pm
    thank you Barend……somehow had not seen this reply before….thanks so much for taking time to answer, she says 6 months later…..eek
    iMac 3.5 GHz Intel Core i7, 2TB; Mac OS 10.6.8, 16 GB RAM; 2 La Cie external HDs 1 TB each; STP 3.0.1; FCP 7.0.3
  • Hope Holmesby
    January 25, 2012 at 6:09 pm
    thank you adam…appreciate….
    yes, thank you so much for pointin that out…
    you are very kind…
