Activity › Forums › Maxon Cinema 4D › Jpeg sequence not working when rendering C4D R19
  • Jpeg sequence not working when rendering C4D R19
    Posted by Muhammad Yusha on May 18, 2019 at 5:01 pm
    Hey,
    I’m working on a project where im using a voronoi fracture to break through a ground in a motion tracked footage using c4d, in simple words I’ve tracked the camera using c4d and voronoi fracture is used to break a simple ground plane. But the problem is that the jpeg image sequence is not playing when i render it, Its just stuck on one frame (it plays in the motion tracker of c4d though).
    I’ve tried checking the box “Animate Preview” in the material. Doesn’t work.
    But the same footage in mov format works perfectly but then afterwards when imported in after effects, it doesnt sync with the backplate so I decided to do this all in jpeg sequences so i could keep the track of the exact frames and stay in sync. I might have missed something in the details so you can ask me more details about the project.
    I wanna deliver the work asap so please give me a solution to this. Thanks in advance ☺
    Sincerely,
    Muhammad Yusha
    Brian Jones replied 7 years, 4 months ago 2 Members · 1 Reply
  • Brian Jones
    May 22, 2019 at 9:19 pm
    perhaps too late now but for future info, jpegs should work but when using images it’s necessary to click on the image name in the texture, which should take you to the Bitmap Shader dialog, and then hit the Calculate button in the Animation tab there (or enter the Start and End Frame numbers yourself) to let it know what images are being used. That all assumes the image files are named sequentially.
